Arlo baby wont discover device
I am having this exact same problem. Hoping a solution can be posted. I am going to post my own ticket as well, but fingers crossed Netgear can offer a solution for both of us.
I have an Arlo Baby monitor, and have been using it (relatively) succesfully since purchase (dropouts and other issues aside).
Two nights ago, all of a sudden, our baby monitor stopped working. I tried power cycling the battery, and this did not work. I then reset the monitor, and alas this did not work. Finally, I removed the device from the Arlo app, and then tried to reinstall the device, and now I cannot add the device at all.
The Arlo monitor is obviously connected to the network, as it shows up in the Apple Home app, however the app will not let me get past the "discover device" screen, where I get an error.
Please provide a solution to this problem.
You state it had previously stopped working....
It may just be defective.
Contact Arlo support ; https://www.arlo.com/en-us/support/contact.aspx
Hi @Amduff
Due to the amount of issues described I have opened a case for you. I will contact you via private message with further information.
Hi everyone
I have 4 Arlo camera connected and set up to the Arlo app .Recently I purchased Arlo baby monitor .I tried several attempts on different days to connect the baby monitor to the app every time the app cannot recognize the Arlo baby monitor ,I tried manually to enter the Qrl and the WiFi connection .the camera would read the code and blink but still the app cannot connect .I tried to reboot the baby monitor didn’t work either .I don’t know if you guys have any suggestions.i followed all the steps in the video .I tried to call the customer service,it seems there is no number to call .I called a number said Arlo and netgear customer service .The IT had access to my computer and cameras then he said I have unauthorized users on my WiFi and things need to be clean on my computer then he asked for 150$ to do it .I doubted that it is the Arlo customer service the guys accent was indian .please help with suggestions and the actual Arlo customer service . Shall I return the baby monitor ?
Support is here ONLY ( do not google as you will usu get a fake service )
Do you do a full reset on the Baby ( hold reset for about ten secs till the led flashes ),
then attempt to sync
I'm one more customer with exactly the same problem.
This problem has been informed by many users.
I'm tired of reading the same "solutions" over and over, that simply don't work.
These devices are truly frustrating.
To all having the disconnect issue get used to it. Arlo support is non-existent, all they will do is ask to you do moronic things like walking closer to your router, resetting the device, or rebooting your router. This problem didn't exist until about mid-June and after several attempts everyone appears to be clueless yet firmware was released for their other products for the very same issue. It will continue to happy like clockwork every 3 weeks or so. My advice is to return it for something that works.
Side note - Arlo Support Chat doesn't work.
See this article on how to perform the factory reset. What is does not say is that you have to take off the ArloBaby ears first but the rest is simple enough to follow.
Our Arlo Baby could not connect and after removing the device and numerous unsuccessfully searches to locate the device during setup the factory reset did the trick.
https://kb.arlo.com/1282685/How-do-I-reset-Arlo-Baby-to-factory-default-settings
Arlo Baby
