How to update firmware on the Arlo Baby when battery is drained and don't charge? Or skip this update, because it blocked video streaming and communications.
Arlo Baby
Arlo
Arlo Baby
Cameras
You can try to update the camera manually, however if the camera will not turn on the update more then likely will not complete.
https://www.arlo.com/no_no/support/faq/4736/How-do-I-update-my-Arlo-firmware-manually
Unfortunately, it doesn't work for me, the same thing (asked to charge battery).
It sounds like you are going to need to replace the Arlo Baby with a different camera. If the battery is no longer charging there is no other way to get the firmware onto the device.
Arlo Baby
