Arlo baby not charging
Are you using the original charger and cable that came with the Arlo Baby? Have you got another you could try?
Check on the web ( https://arlo.netgear.com/ ) and verify if the 1) level of charge 2) lighting bolt in battery icon...
Is the Baby working when plugged in ?
( check battery switch under feet , 1/4 turn twist to get off )
Can you plug another device eg mobile phone, into the charger+cable to verify the charger is working?
Guess the last thing to try is a factory reset with the little pin hole
Hi @Slagish,
Were you able to try out the troubleshooting steps that were given on here by steve_t and TomMac?
I have the exact same issue.
holds charge for a short while then dies and will not charge again. I have tried other cables etc but same issue and the arlo baby cables work with my other arlo pro cameras fine.
its the battery in the baby and it’s only about 14months old, does anyone have a fix, m in New Zealand and this product has a 24 month manafacture warranty so I want to return this to netgear.
So basically im nt even sure the battery ever worked since it was always plugged! I tried turning on and off the battery switch bt in both cases it wont charge.
Hi Yanna,
Are you using the power outlet that came with the Arlo Baby? Have you tried plugging in on a different power outlet? If it still doesn't work, contact the support team so they can look into it: Arlo Support
Hi Jessica,
yes im using the power outlet that came with the arlo baby, and tried different power outlets in different houses. im pretty sure its a manufacturing defect since it never worked. i guess ill have to contact Arlo support
If you still have the store receipt and still in the warranty, take it back and exchange it.
Will be far faster than dealing with Arlo support. Trust me
Arlo Baby
