Arlo Baby Bottom Screw
I lost the screw that connects to mounting hardware that was on the bottom of my Arlo Baby. Is there a place to buy replacement parts?
5 REPLIES 5
I called yesterday and they told me that they cannot send parts and do not have a place to buy them. They said to check with a authorized seller like Best Buy to see if they have extra parts.
@ShayneS wrote:
If support can provide you with a spec, I am sure you can find one at the local hardware store. Possibly @jguerdat, @TomMac may be able to provide some insight.
It is the standard 1/4-20 threaded bolt use in all the mounts ... any good hardware store could supply one of various lengths as needed
Arlo Baby
