Arlo baby is Flashing purple at night
Hi, my Arlo baby flashes purple at night and wakes my baby up. Anyone had similar issues?
Usu the flashing purple is showing the camera is at max range for signal... ( Q cam does the same )
If the camera is functioning, the only answer is to put a small piece of tape/bandaid over the led as the led toggled off in the settings does not stop this.
Thanks @TomMac,
When you say signal do you mean WiFi ?
yes
Arlo Baby
