Arlo baby- impossible to change desired audio detection
  • 6 Replies
  • 1976 Views
Tiivh
Bought a new Arlo baby but the audio detection level is set to 0 and impossible to swipe. Useless without this feature. Please advise!
6 REPLIES 6
ShayneS
Hi @Tiivh
Are you still experiencing this issue? What Device/Model/OS/Arlo App version are you using?
What troubleshooting steps have you tried so far? I do not want to suggest anything you may have previously performed.
Tiivh
Hi Shayne,
Have tried to uninstall but that didn't work. The audio detection is on level 0 and not possible to swipe right.
I use the iphone app, latest version on Iphone X. Attatching device info as well.
Would be great if you can help solve this.
Lade
Are you the main user, or did you get an invite from the main user. Maybe it's because of a rights-problem?
Jonn
ShayneS
Hi @Tiivh
I have reproduced this issue & I will look in to this issue for you. Thank you for your patience.
Valerietpillai
Hi there, have you managed to find a solution? I am having the same problem as well, this was after i downloaded the new app. Thanks
ShayneS
Hi @Valerietpillai
  Have you tried contacting customer support regarding this issue? I have attached the link here for you - Arlo Tech Support
  • 6 Replies
  • 1977 Views
