Arlo baby excessive white noise / hissing
I have just bought the Arlo baby and have just started using it but in live mode and in baby monitoring made there is a constant hiss. I have turned the microphone sensitivity down to 2 but it doesn’t seem to make any difference.
Is there any way to remove the constant hissing which makes this almost impossible to use as a baby monitor, especially at night. I am sadly considering sending it back.
I have a nest cam and have no such problems with constant hissing.
Any help would be much appreciated.
5 REPLIES 5
Does it make any difference where your camera is located? Does it make any difference if your phone/tablet (whatever you're using to monitor the camera) is on mobile data rather than on the same network as your Arlo Baby?
@steve_t Have the same issue in my Arlo Baby that I bought this week.
Does not matter the location, it always make the wite noise, I turned down the volume to 50% and its kinda better.
Integrated with homekit and oppening the camera thru it does not make the same noise, I belive that arlo app need some improving.
Oh, that's very interesting. Do you get the noise when you view the Arlo Baby through the web client?
I have not trested out with the web client
I hear the excessive noise as well on the Arlo app. When using via Apple Home it works fine. Disappointing.
Arlo Baby
