Arlo Baby stops 30 secs after turning it on battery or plugged to power
  • 1 Reply
  • 1356 Views
JuMAx_SG
Hello,
We purchase our Arlo baby second hand. At first it was working perfectly and matching our needs.
For the 2 past days, the camera stop 30 seconds after turning it on on battery or plugged to the power.
What solution do we have to fix the issue? Thanks
Model: ABC1000
S/n: 50E38BSG85E12
First, make sure the battery is turned on ( under feet ) and the ac adapter is in good working order... ( test with another device like phone, etc )
Second, I would try a full reset on the Baby... Remove baby cam ( remove device ), then hold in the reset for 10 sec till the led flashes.
You will have to reclaim/setup the baby cam as if new.
  • 1 Reply
  • 1357 Views
