My Arlo Baby has been acting weird ever since the latest update. It takes longer to connect and show a visual. When the screen does come up, the music and temperature are missing. I have closed out the Arlo screen and tried again - nothing changes. It ‘sporadically’ reappears and I have no clue why. Does anyone have any clue why this is happening. It has taken me up to 15 minutes to finally get the music on after countless restarts and failed attempts. Also, is there any way around the two-step activation. I know it goes into affect in September and I’d rather not use the function. Any help is appreciated. Thank you!
Hi Jmewick12,
Have you tried reinstalling the Arlo app and/or rebooting your phone device to see if that helps?
Hi bychance,
Have you tried reinstalling the Arlo app and rebooting your iPhone as mentioned above?
Hi Cjfreyja,
What Android version are you running? And what Arlo app version are you running? Can you show a screenshot where you don't see the music and temperature? And does this happen on both WiFi and/or cellular data?
I'm using Arlo version 2.22.5_28260. I have a Galaxy S9 phone. Currently updated to Android version 10 on TMobile. My husband has the identical phone, operating system, and arlo updates and he is NOT having this issue. Also, I tried logging in from my computer and was able to access Arlo on Google Chrome with full function of all the buttons yesterday.
Is this happening on both WiFi and/or cellular data? Have you also tried rebooting your Galaxy S9 to see if that helps?
I would suggest to contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
Arlo Baby
