It was working find for couple of month, but it has been a month it wont work and it is Solid Amber.
Tried the soft reset turn off the battery. Also, the solid resetting it to factory settings still it doesn't work.
Hio @nawafalohali
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
Arlo Baby
