Arlo Baby and New Arlo App
  • 1 Reply
  • 1227 Views
CameraFunTimes
Is there a way to arm/disarm the Arlo Baby independent of the predefined modes in the new app? We tend to arm/disarm depending on when the little one is sleeping, which doesn't necessarily fall into line with Arm Away/Arm Home.
You should be able to go into the camera's settings and turn it off.  Though that would also disable the other sensors in the camera.  You'd also have to turn it back on for live viewing.
Also, although the modes are built-in, you can change the rules in them.  The names are just arbitrary labels, you can use the three modes any way you want.  So if this is your only camera, you can certainly re-purpose Armed Home for "child sleeping".
  • 1 Reply
  • 1228 Views
