Arlo Baby Device Settings change every time it is off/disarmed
  • 1 Reply
  • 861 Views
natedilling
I have the Arlo Baby. Device settings should be saved indefinitely once I set my preferences. They should remain as I set them until they are manually adjusted again. As of right now the device settings reset every time the device is turned off or "monitoring" is turned off. This is a major inconvenience but could be corrected with a minor fix.
ShayneS
Hi @natedilling
  Have you tried contacting customer support regarding this issue? I have attached the link here for you - Arlo Tech Support
  • 1 Reply
  • 862 Views
