Arlo Baby Device Settings change every time it is off/disarmed
I have the Arlo Baby. Device settings should be saved indefinitely once I set my preferences. They should remain as I set them until they are manually adjusted again. As of right now the device settings reset every time the device is turned off or "monitoring" is turned off. This is a major inconvenience but could be corrected with a minor fix.
Hi @natedilling
Arlo Baby
