Arlo Baby ABC1000 - "Device Not Found" - Won't Register to the Arlo Application
  • 2 Replies
  • 1622 Views
CrozierSam
Hi There,
I have just got a new Arlo Baby camera provided as the last was faulty after four months of use. Upon opening, I have found that this "new" camera will not successfully register against my Arlo account. I am able to follow the instructions of the application registration process via QR code, however when I do so, the device doesn't get past the discovery process. It kind of hangs and then eventually times out.
I would also like to point out that I have tried the following:
Made sure the same WIFI network is being used by the device and camera
The chime is heard when the QR registered
I have tried resetting the camera
What am I suppose to do next? I am trying to contact Support but this page seems misleading as no chat resources are available.
I have found so many similar cases of this, (https://community.arlo.com/t5/Arlo-Baby/Arlo-baby-device-not-being-discovered-Had-reset-device-and-b...) where users are unable to register their Arlo Baby cameras within their smartphone applications. Why are so many people having the same problem? If I can't get this solved, I will have to take up further with the governing bodies as I feel like I have been let down as a consumer.
Thanks,
ShayneS
Hi @CrozierSam
I have escalated your case & customer support will be reaching out to you as soon as possible. I have provided your case number here. 41608005
CrozierSam
Hi @ShayneS ,
Thanks for following this up. I have also called through to the support team today, who have created case number #41609484 for this issue.
Additional steps attempted on the phone with no resolution of the issue:
  • Hard reset of the Arlo Baby Camera (Hold reset button for 30 seconds)
  • Sync using the Router WPS button
  • Disabling Router Firewall
If someone can get this resolved for me as soon as possible that would be great.
Regards,
  • 2 Replies
  • 1623 Views
