Arlo App Crashes On "Always Listening" Mode
  • 1 Reply
  • 1005 Views
kiwigodss
Ever since the Arlo app update (or possibly the newest iOS update - happened around the same time so hard to pinpoint), "Always Listen" mode is faulty for me, and I don't know why. Yes, I know the icon changed with the app update (those few days with the Home Kit were fun), and that now if "always listen" is running, what you'll see is the head with the X next to it to indicate that you hit that to turn it off. So I know I'm using it properly, but when I lock my phone and leave it going, it only makes it about 10 minutes before the app crashes and the sound is gone (at most). My lock screen will still show that the audio is playing, and at the correct volume, but no sound is actually coming out, and when I unlock the phone, the Arlo app has crashed and I have to restart it. Can anyone help? It's really bad that I can't count on the app to keep running while I sleep anymore! It's impossible to use this as a monitor if it's just going to cut out..
ShayneS
kiwigodss,
What iPhone Do you have? What version of iOS & Arlo Mobile App are you running on your iphone?
Have you tried to reboot your phone & remove & re-install the Arlo Mobile App?
  • 1 Reply
  • 1006 Views
