  • 4 Replies
  • 2645 Views
ABChandler
I am receiving a message stating "Maximum of 5 camera streams are supported simultaneously. Please stop one stream before starting another camera stream."  We do not have 5 cameras for Arlo. Can anyone assist? I've logged out and logged back in, multiple times. This message is not allowing us to view the camera feed.
Dannybear
You could check how many users are logged in to your account, check this by going to settings in the app, select privacy centre then select account and  select sessions. Log out any that you don’t want.
ABChandler
Hi! Thanks for that, I did just check and it's only showing me as a user. There are only two users for this camera, and the system never allows us to view the feed at the same time. Unfortunately, I still don't have a solution to this issue. I don't know what to do at this point.
Dannybear
Unfortunately the prior threads on this forum describing a similar issue, point to a arlo backend server issue.
Since it can take several months for arlo to identify the issue and deploy a fix you should start the arlo customer support process as soon as possible.
If you’re subscribed to a plan or the equipment is still within warranty you can access support via the arlo app settings/support/device for your entitled options.
 If you’re not entitled then you will need to wait for other customers to complain about the issue.
ShayneS
Hey @ABChandler
Are you still experiencing the issue? is this occurring over the web browser or mobile app?
  • 4 Replies
  • 2646 Views
