Sharing Chime
Hi, I just bought an Arlo Dorbell and Chime, but my system have 3 base stations (they are allowed to be accessibel in just one account), as in Brazil we are not able to by a the plan to have more then 5 cameras per base.
So in this configuration I have cameras in all this 3 basestations an would like to know, if I sync the doorbell in one basestation (that will work the camera together to the doorbell) and sync the chime in other basestation it will work or I must sync the chime and doorbell only in the same basestation?
You can't "share" it accross accounts. Only within one account.
Ok jguerdat, so the chime always should be connected to the same base station as the doorbell?
Thanks,
In your case, because you have separate accounts, the answer has to be yes, the doorbell and chime must be synced to the same base.
