Screw at bottom of Doorbell is stripped. Can't loosen to replace batteries.
  • 4 Replies
  • 4153 Views
Kanders78
The screw at the bottom of the doorbell is stripped and I can’t loosen it to replace batteries, help!
The only good way to remove a stripped screw is to drill the center with a small bit ( smaller than screw ) and use an easyout ( reverse twist extractor )
MNHockey
Did you ever get the screw out? Currently struggling with the same problem
Kanders78
still struggling with the same issue, the battery is completely dead and the unit is useless at this point
Have you tried different screwdrivers with a #1 phillips bit? Maybe a set of jeweler's screwdrivers could be useful (use the larger sizes). A small straight slot screwdriver may be useful. Go slow to prevent tip slippage.
Too late now but one thing I do is to only snug the screw rather than trying to tighten it. Also, use of good quality screwdrivers helps since cheap ones (like the one supplied) have questionable tip shape.
  • 4 Replies
  • 4154 Views
