Hi @Tenorric,
You can read from the following on how to set up the Arlo Audio Doorbell and Arlo Chime:
So to confirm, you can use 2 doorbells with a single arlo chime? Can you have different sounds for each doorbell?
Hi @Sircoynie,
Yup, you can pair more than one Arlo Audio Doorbell with an Arlo Chime. And yes, you can customize the Arlo Doorbell's melody so you know which doorbell rang.
Great, thanks for letting me know!
Now can you get them to also fix the Alexa integration, the skill for the doorbell is broke and not working! Thanks
w you can customize the Arlo Doorbell's melody so you know which doorbell rang.
You can customize the Arlo Doorbell's melody so you know which doorbell rang.
Why the links which have nothing to do with the rest of your post? Is this a spammer?
