Is Arlo Chime necessary? Can I use the Base Station to produce sound?
  • 2 Replies
  • 1287 Views
JTDUB
Hi, I have the Arlo system with 3 cameras and 1 base station. I am thinking of purchasing the door bell; however, is puchasing the plug-in chime necessary? Or can I use the base statio to chime? I figured I would be able to since it produces a sound (siren).
Thanks,
Joseph
No, the doorbell will not activate the base's siren. You can use either a pre-existing chime (wired) or the chime.
skingspan
Luminary
Luminary
You can use and Alexa dot or show device as a chime.  Some on this forum have had issues getting alexa set up though.  I have alexa set up as a chime and I find that it is not loud enough to hear everywhere in the house so I bought the chime as well which is much louder and can be heard throughout my house.
https://wickedsmarthome.blogspot.com/
  • 2 Replies
  • 1288 Views
