I would like the Arlo Audio Doorbell to ring my existing wireless chime from Heathco LLC
  • 4 Replies
  • 1885 Views
inthemix58
I have an arlo audio doorbell. When you push the button, I would like it to ring the existing battery operated wireless chime in my home. The chime is manufactured by HEATHCO LLC Bowling Green KY. Is this possible? Does Arlo make an indoor chime?
inthemix58
Thanks so much for your fast replies.  I just placed my order.  Have a great evening!
it depends on the type of chime ; electrical/mechanical or electronic....
Yes, arlo does have an internal chime ; https://www.arlo.com/en-us/products/arlo-doorbell/chime.aspx#AC1001-100NAS
inthemix58
I can't find the arlo chime that is wireless?  I would hate to go back to a wired chime.  The power is in the wall, but I would need an electrician to find it?
The Arlo chime simply plugs into wall power and uses the base's WiFi connection
inthemix58
  • 4 Replies
  • 1886 Views
