  • 2 Replies
  • 1123 Views
Gilquin
I just moved into a new home and it has an Arlo wireless camera doorbell.
However, the previous owners did not give us any instructins on setup or anything.
How can I set it up for my use?
Thanks!
You sync it normally via the Add Device selection on the Devices tab. Of course, the previous owner has to have removed it from his account first. It amy also eed fresh batteries.
Louis_ArloPM
Hi,
Follow the step from our super user. You'll need an Arlo Base station for your Arlo Audio Doorbell to work.
I also recommend you reset the doorbell prior to attaching this.
So:
Check with the previous owner to remove the device from their account
1) make sure you have an Arlo system and account setup and running, with a base station
2) replace the batteries (if low)
3) Do a reset of the doorbell https://kb.arlo.com/000061842/How-do-I-reset-my-Arlo-Audio-Doorbell
4) Add the audio device in your device view and follow instructions to set the device up
  • 2 Replies
  • 1124 Views
