I have tried setting up the Arlo Doorbell to my existing connections. Like other users have stated, there's a constant buzzing on 1 and 3 with nothing on 2. The solutions I've seen on here indicate a Traditional Chime toggle switch in the settings for the doorbell, which I do not have on my app.
Under customize, I only have the Silent Mode option. When that is active I get the Incoming Call option.
Nothing I do brings up the Traditional Chime option.
If I enter the device settings, the first section only has Battery, Connected To, and Device info. No Traditional Chime option there either.
Is there something I'm missing?
Hi! We have the latest software version and continue to get the continued buzzing with our existing chime. Upon taking the cover off of the Arlo doorbell, and it being slightly ajar, it will operate as it should, but once securing the cover, back to continued buzzing. Help!
Hey @JeffKenn
Have you contacted customer support about this issue? I have attached the link here for you. Arlo Tech Support
@RichWen wrote:
Hello Randal. Arlo hasn’t contacted me yet about this. I just checked the difference between my IOS devices versus the google chrome laptop and the apps are different. My IOS devices do not give me an indication of tradional chime in the settings but the google device says traditional chime “connected”. After PLENTY of hours trying to get the doorbell to work with my iPad or iPhone, I tried the new google chrome laptop. By removing the device first from Arlo, then adding the device and then pushing the resync button on the doorbell for at least 10 seconds (or until the doorbell’s led ring flashes fast). I then follow the Arlo instructions by getting it to get the latest firmware for the base station, then find the doorbell...and at the end when I’ve connected the doorbell back onto the attached wiring base, I try the doorbell, it works. IN MY OPINION, THE TRADIONAL CHIME WILL NOT CONNECT WITH AN IOS DEVICE. It will only work with others that have the traditional chime showing in the settings of the doorbell.
