Doorbell won't chime when connect to existing M&S intercom system
  • 5 Replies
  • 3423 Views
Mced
I am trying to setup my Arlo doorbell with my existing M&S intercom system. I have all the wires connected and go through all the setup in the app. I can get call on my phone but the existing chime won't wok. I tried to switch to all settings, either non-stop chiming or no sound. I thought the doorbell will work with existing chime as I don't want to invest more money on several more Arlo chimes. Any suggested setup to get this working? Thanks.
5 REPLIES 5
ShayneS
Hi @Mced
Have you tried contacting customer support regarding this issue? I have attached the link here for you - Arlo Tech Support
Mced
Thanks for your tips. I will send Tech Support a note.
ShayneS
@Mced
You are welcome!
Let me know how everything goes.
Mced
I sent a message to Tech Support and it has been a week, no reply yet.
Mced
Tech Support has called me back but I was told intercom system is not compatible with Arlo doorbell. This should be clearly documented in the product so that people are aware that it may or may not work with their existing system.  The only solution left is to spend more money and purchase 1 or 2 Arlo chimes
  • 5 Replies
  • 3424 Views
