Doorbell disconnect, battery drain and poor voice quality
  • 2648 Views
BMurdock
Hello,
My Arlo doorbell constantly disconnects (full signal), the battery is now reading 0%, and the default voice responses cut in and out all choppy...
Are these consistant issues or have people had this doorbell function properly?
I have had 0 problems with the base station, cameras, and chime, other than when the doorbell acts up. I find it extremely disappointing given the amount of money I spent on the system, that I have so many issues. I specifically replaced a Ring doorbell for better video quality and camera placement and have the camera triggered by the doorbell. If the doorbell doesnt work it's now pointless.
ShayneS
Hi @BMurdock
When did this issue first occur?
What troubleshooting steps have you tried so far? I do not want to suggest anything you may have previously performed.
BMurdock
It started about 2 weeks after I hooked it up. I have tried replacing the batteries, moving the base closer, re syncing the device, I have even factory reset everything and set the whole system back up.
ShayneS
Hi @BMurdock
There was a new update for the doorbell released last Thursday on the 8th of August. Have you tried to remove & re-sync you doorbell since then?
  • 2649 Views
