  • 2 Replies
  • 650 Views
Uncfan1976
I have the doorbell installed and paired with camera successfully. I have a motion alert set on the doorbell thinking that if motion is detected it would trigger the camera to record and I would find video in my library without having my entire system armed.. Am I missing a setting or something?
No, if you set up the mode properly, it should work as you have stated.
verify the mode is correct.
You did set this up in the doorbell settings under Motion and Audio Settings, right? Also, note that you can't enable/disable the settings from the web - use the app to do so.
  • 2 Replies
  • 651 Views
