Doorbell and Alexa
So I found a YouTube video that says to add routine and then add doorbell well it never finds doorbell. So best I can find is that I have to use the skill. Is this correct?
Ok it showed up for a second then after I set up chime it disappeared.
Hey _DrUnKeN_TiGeR_,
Can you elaborate what problem you're specifically having with your Arlo Audio Doorbell? Are you having problems syncing the Arlo Audio Doorbell with Amazon Alexa and/or through the Arlo app on your phone device?
