Doorbell and Alexa
  • 2 Replies
  • 1562 Views
_DrUnKeN_TiGeR_
So I found a YouTube video that says to add routine and then add doorbell well it never finds doorbell. So best I can find is that I have to use the skill. Is this correct?
_DrUnKeN_TiGeR_
Ok it showed up for a second then after I set up chime it disappeared.
JessicaP
Hey _DrUnKeN_TiGeR_,
Can you elaborate what problem you're specifically having with your Arlo Audio Doorbell? Are you having problems syncing the Arlo Audio Doorbell with Amazon Alexa and/or through the Arlo app on your phone device?
  • 2 Replies
  • 1563 Views
