What settings, if any, are available for the motion detection feature? Can you turn motion detection on and off? Can you adjust the sensitivity either through the Arlo app or by placing a membrane over the sensor?
The amount of sensitivity is adjustable in the mode your using to arm the cameras....
Read the FAQs, there's a lot of basic info there
If you're referring to the doorbell itself, there's no sensitivity setting. You can turn off the detection that will trigger a camera.
