  • 1388 Views
Gfat
Hi , does anyone who has one please tell me if you can trigger more than 1 camera ? Also can you select the trigger? Eg the doorbell button over the motion sensor or is the only trigger the motion sensor. I am wanting to enable a button press to trigger 3 cameras at the same time. Many thanks to anyone who can answer this for me
There is no button to make multi cameras record....
BUT, you can cross trigger ( it used to work perfectly but lately has been abit wonky as to all recording )
You create a CUSTOM mode.
Add camera A to sense and A to record....save
Go back and edit the new mode to add a second ( or additional ) camera
Add camera A sense and B record save
etc as needed
Exp with 2... it can be re sense / record
A  A
A  B
B  B
B  A
In the case of the doorbell, it is the doorbell that would cross-trigger the camera(s).  This can only be triggered by the doorbell's motion detector, not pressing the doorbell.  So you'd end up with more recordings than you might want.
Gfat
Thanks for the replies. Exactly what I needed to know . I think I will just wait for the new sensor to be released as will suit my situation better.
  • 1389 Views
