Arlo Chimes will not work together
  • 2 Replies
  • 1075 Views
GPast1
Only one arlo chime will work when call receive button is active. If I select both chimes it goes into the silent mode default. I tried to install and uninstall both and they still won't work correctly. If it's in call receive only one chime will work. What's next can I do? Restarted base station still won't work right. Is this a common problem?
ShayneS
When uninstalling the chime did you unplug it from the outlet or perform a reset by holding the side button for 10 seconds? Did you remove the device from the settings?
GPast1
After doing all the recommendations, the only thing that worked was not using my Samsung 8 phone for setting it up. I used my apple ipad to do that then everything sync together. Wow, very frustrating!!!!
  • 2 Replies
  • 1076 Views
