Homekit token reset
zmit
Hello
I successfully added my smart hub to homekit once, but I had to re-do the homekit setup. Now I am stuck at the "Devices found" stage of the hub's homekit section. Reading around the community pages it seems like I need to get a token reset to be able to re-add the hub to homekit. Can you please push one to the hub associated with this account?
155 REPLIES 155
BrookeN
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions:How do I connect my Arlo device to Apple HomeKit?
Baron81
Finally found an open topic! So many marked as solved! I also need another token reset sent to me after 6 months of working it’s now stopped again!
thank you!
BrookeN
Guitarguy0124
Can I get you to reset the token for our base station. I just spent an hour with support and the guy had no idea what I was talking about. The main user on the account is my dad,
Best not to post email addresses publicly.
Are you certain you were talking to Arlo support?  The only way to reach them is via the support center in the app.
Guitarguy0124
Yes. I was talking to their product support in the app quoting them everything from these threads and he still insisted he couldn’t do anything to the hub.
Can you not reset it like so many others have had theirs reset in these threads?
BrookeN
@Guitarguy0124
Guitarguy0124
Just out of curiosity. How do you know which hub is mine as it isn’t assigned to my account. I am just an add-on user.
Ribeye
I need reset token sent. Unable to connect to homekit after app update.
BrookeN
Guitarguy0124
The token reset didn’t work. It would be so much easier if I could just get the HomeKit setup code. Is there no way of looking that up?
BrookeN
We do not have the codes for the Homekit set up. Try logging out and logging back in and then setting up Homekit. If that does not work you will need to reset the basestation fully and then set up up without the code.
amxing
Hello Arlo,
My hub station required a token rest as well. Thanks.
icarusbon
Hi @BrookeN,
I have the exact issue and can you do me a favour to reset the token please? Thanks!
Tjaeger
I do have the same problem I believe. I cannot add my vmb5000 to Apple home.
do I need a token reset?
Tjaeger
I got it reset myself. No further action needed at this time. Ty.
BrookeN
https://kb.arlo.com/000063184
Jbl7
Can I please also have a token reset? I am trying to add my Pro 5S cameras to HomeKit now that the firmware is updated and I have already tried resetting the base station and adding to HomeKit from within the Arlo app and the Home app
BrookeN
Jbl7
Thank you so much Brooke, it is working!
KSParis
Hello,
May I also receive a token reset?
BrookeN
Mac42nd
Hi it’s been four months and I have no way to contact you other than posting in a community forum? I work in stores that sell your product, and I definitely can’t recommend them now.
BrookeN
@Mac42nd what can I help you with?
aimaixing
I also need token reset. Thanks.
