Forced to do lastest app update. My cameras no longer work. Have uninstalled and re installed. Still doesnt work. Cant access cameras I have granted access to.
You will likely need to get the admin account to remove your sharing and invite you again. I don’t think the app is that smart to reuse the older UI settings.
What UI version do you have, the original one with library or the new that has feed? and is the admin account using the same?
@Annarose26 Are you still experiencing this issue?
Yes I am
