Introducing Arlo Ultra - FAQ & Resources
Protection Perfected
Arlo Ultra 4K wire-free security camera delivers the ultimate peace of mind with advanced video and audio quality. Easy to install, the camera displays a wider, panoramic view with enhanced, color night vision. The integrated spotlight lights up the night or helps to ward off unwanted visitors. Advanced noise cancelling technology also minimizes background noise for crystal clear, two-way conversations. Easily connect to other smart home devices with the included Arlo SmartHub. Arlo Ultra Systems also includes 1 year of Arlo Smart Premier service.
For more information about your Arlo Ultra System, and some other helpful resources, check out these articles below:
- What is new in the Arlo Ultra camera?
- Arlo Ultra FAQ
- What are the benefits of 4K in a security camera?
- What is Auto Track and Zoom on my Arlo Ultra camera?
- How do I stream in 4K with my Arlo Ultra camera?
- How does the spotlight on my Arlo Ultra camera work?
- What Arlo subscription do I need to record videos with 4K resolution?
- Is Arlo Ultra backwards compatible with my existing Arlo system?
- What is different about the new mount for my Arlo Ultra camera?
- What are the benefits of the SmartHub?
- How do I adjust the field of view on my Arlo Ultra camera?
How do I position my Arlo Ultra camera to detect motion in specific areas?
If you have any questions about the Arlo Ultra System, post down below and we'll get to each one as soon as we can. If you need any more help on your Arlo Ultra System, visit Arlo Support for more articles and resources.
Buy your Arlo Ultra System now on Amazon and Best Buy.
Thank you for being part of the Arlo family!
Dazler,
To access live view, your SmartHub and viewing device would need to have an internet connection.
If your internet was down, you would not be able to access a live stream.
Do you think this is something that could be done in the future with a firmware update?
Or there would be no way due to hardware design.
I had WiFi but internet was down due to lightning.
It would be great if in this scenarios it would allow you to live view from inside the house WiFi and also record any outside movement.
Dazler,
Arlo is a cloud based system. To live stream, you must have an internet connection.
However, in your scenario, it sounds like the local storage backup feature could be beneficial. This would allow you to continue receiving recordings locally to an SD card as long as your SmartHub remains powered and the mode was set to "Armed" at the time the internet connection was lost. This won't allow you to live stream, but you would be able to continue receiving recordings from the cameras locally.
Take a look here for more information: How do I record 4K videos to a microSD card?
I recently bought a 2 Ultra camera system and all worked great upon install.
I was having some connection issues with one of the cameras where I could never go to “live” feed and the camera would not sense me when I purposely tried to trigger the motion.
I removed the device and tried to re-add. It’s been two days & nothing seems to work to get the camera back online.
I’ve tried sync, resetting camera and modem... nothing
I’ve tried using my laptop, battery is fully charged...
The lil blue light will blink and then rapidly blink before it goes off and the apps is left still searching
Thoughts on how I can get this camera reconnected?
JUJ326,
Try rebooting your SmartHub and bring the camera close (within a few feet) and attempt to sync again.
Do you still experience the same behavior?
Hey I'm having trouble getting wifi signal for 3 cameras, i got the basestation in the middle of the house but front & back only gets 1 bar red wifi signal.....what is an cheap alternative route for me to get all cameras with better signals? Thanks in advnace.
iCanSeeClearly,
You could add additional SmartHubs (no limit) and position them close to the cameras having issues. Each SmartHub would need an internet connection.
You could also try elevating your existing SmartHub and moving it away from other WiFi sources (nearby routers, smart devices, etc.) as they could be causing interference. This may help improve the signal strength from your SmartHubs current position to the cameras.
I am still unable to resolve my 1 year free subscription for Arlo Ultra even though I am in Singapore where the Smart Plans are offered. The cams are lying there useless for almost a month. I do not know what the strategy is for Arlo.
trying to install , Have installed app when I go to add new device sends me back to app install and shows installed
ventosa,
It's not clear what issue you are experiencing. To get started, first navigate to the app store on your mobile device and download the Arlo mobile app. After the mobile app is installed, tap "create account" and follow the on screen instructions.
Accessing Local Storage
