Some weird issues can happen when firmware isn't up to date. It'll be a PITA but try a reset. Remove all devices from Settings, My Devices and start fresh. Use the Add Device button in the Devices tab to add the base and sync the cameras. Check for firmware updates in Settings, My Devices, your various devices and wait overnight for them to be automatically installed if it doesn't work right away.
That's not going to cut it. I need a reliable camera for crooks. I didn't buy it to troubleshoot. It's hard to find how to contact support too. Taking it back tomorrow.
It's hard to click on the Contact Support link at the bottom here?
Cute. The link takes you around and around. The Chat gives you a number and tells you to give it to support but the chat window never populates. Maybe you have time to sit and play here all night, but I do not. My money and I'm not happy with the dificulty contacting support.
Just tried it and it works fine. Several options to communicate including chat, email and phone.
We can lead you to water but we can't make you drink. If you aren't bothering to state your problem, what you've tried, whether the possible solution posted above helped, made contact with support, etc. etc., ad nauseum, go right ahead and return them so someone else can get use of the system. I won't miss you.
I had an issue early on there those settings dropped away.
