Just to be clear, the only way to extend range is to buy another base station? I dont think thy sell them separately. Since this product is net gear, why cant they just put out a range extender or use existing wifi. This is terribly disappointing. I probably would not have purchased htis product if i new it communicated via the base station and not my WiFi network (which has strong signal everywhere).
Correct.
I dont think they sell them separately.
They do. You'll find them at shop.arlo.com, but perhaps they'll be cheaper elsewhere.
It's not Netgear - Arlo spun off from them quite a while ago now.
FWIW, some of the newer cameras are able to use either your WiFi or a base station. That is the case with the Video Doorbell, and also the new Pro 3 Floodlight. So I think they have heard this feedback.
