Hello Arlo!
First of all, nice work with Arlo Pro!
I am planning to create a smart home and use the protokoll Z wave. Are Arlo Compatible with Z wave so that I can intergrate the cameras in my smart home?
Thanx in advance!
// Boggyman
No but the system is compatible with Smartthings, which has both Z-wave and Zigbee radios inside
Hi Steve,
Was planning to use Vera Control - Vera Plus (Gen 5) that use Z-Wave Plus, ZigBee, Bluetooth, LE Wi-Fi (802.11 a/b/g/n/ac).
So if I understand you correct I can use Arlo Pro with Vera?
// Boggy
Arlo is only compatible with SmartThings and that is fairly limited at this point. Unless someone writes a interface/stack etc. for it to work with Arlo (not sure if Netgear even offer an API etc. as it is a closed system) then you will NOT be able to use it.
Best thing is to search the Vera forums or even google to see if anyone has it working but I think it is pretty unlikely until Netgear allow it to happen.
If you are serious about your home or work security then look elsewhere! Get a ip Camera System with an NVR and some Blink XT cameras to cover the places you cannot run a cable to. You will NEVER regret moving away from Arlo!
AppleTV
21 -
Samsung SmartThings
59 -
Security System
