  • 471 Views
brich4750
Why is it i can setup a Google Home Automation that arms/Disarms my cameras but cannot with Alexa?
BrookeN
You can not arm or disarm the home using Alexa. These commands are the ones that are supported by Alexa:
https://kb.arlo.com/000044725/What-Alexa-commands-can-I-use-with-the-Amazon-Echo-Show-to-view-my-Arl...
BrookeN
Use the following link to insure that the settings are all set up correctly.
https://www.arlo.com/nl_nl/support/faq/000062277/How-do-I-trigger-an-Amazon-Alexa-device-when-motion...
brich4750
I guess i did not explain it correctly.
I have in Google Home setup a routine where i tell google i am leaving and it will change the Mode from Arm Home to Arm Away, and another one that does the reverse.
I do not have the ability in Alexa.
The camera all show up as unsupported when i go to try to control them.
Arlo Essential 2nd gen x4 and Arlo Video Doorbell.
I have setup geofencing and that works in the iOS Arlo Secure app.
BrookeN
