Lost Connection to Homekit
  • 33 Replies
  • 5761 Views
  • 13 In Conversation
Rob38
Hello!
I lost the ability to integrate my Arlo system with HomeKit. I have completely reset my Arlo and HomeKit systems, removed all devices, and re-added them to my Arlo app. Everything works fine if I use the Arlo app on it's own, but when I try to link the Arlo System with HomeKit through the app, it gets stuck on the Arlo App trying to Discover my system.
Any help would be greatly appreciated... Thank you! 🙂
33 REPLIES 33
I've sent a token reset request to your base station that should resolve the issue. Please reboot your base station (remove and reapply power) allow the base station to come back online and try setting up HomeKit again using these instructions: How do I connect my Arlo camera to Apple HomeKit?
MitchellNZ
Hi JamesC, I am having the same issue. Could you please send a reset token request for mine too? Thanks!
MitchellNZ,
MitchellNZ
Hi James, thanks for the quick reply.
Unfortunately, this does not appear to have resolved the issue.
I have pulled the power for 5 minutes, then reconnected and followed the steps in the guide you linked. Its still getting stuck on "Discovering you device. Please wait." after attempting the HomeKit setup.
I have also recently update the Arlo iOS app to the latest version (3.6.3 (3404)) and ensured the device firmware is up to date. (version 1.17.1.2_3987_0e6c162).
Please let me know if there is anything I can try.
Thanks again!
Piston38
How can I request a token reset as I cannot get my Arlo base station to connect with HomeKit?
MitchellNZ
Hi James,
Just following up again.
After waiting some more time, I gave it another go and its working once again!
Thanks for your help.
Piston38,
ldonlin
Hello!
I believe I need a token reset request.
Idonlin,
ldonlin
Unfortunately, that did NOT work…and other thoughts?
amyglen
Hi James,
I'm having the same issue. Could I please have a token reset sent to my base station?
Thanks,
Amy 🙂
ldonlin
Hello James, that fix didn’t work. Now the Arlo Secure App just hangs in “discovering devices”
smurraybu
I am having the same issue and would like to try the token reset as well please
amyglen, Idonlin, smurraybu
ldonlin
Hello James, the reboot did seem to work, however the issue is when I leave the home Network, or the network its provisions on. I lose response of all the cameras, and need to re-add. Is there an additional setting that needs to be changed tweaked or reset on my Apple TV?
ldonlin
Hello All, I believe the solution fix to this issue is the latest version of the Arlo app on iOS. Be sure to check in the Apple App Store that you have the latest version. Then make sure that you have the latest version of the Arlo iOS app and try setting up HomeKit again.
ldonlin
James, I’ve been unsuccessful with all of the steps…please resend the token.
JG222
Hi James - same issue with HomeKit here. Can you please send a new token to my device as well? Thanks!
amyglen
Hi James,
Can I have another token reset too, please?
ShayneS
@JG222 @amyglen
I have reset your HomeKit tokens. Please reboot your base station and test again
Riclicious
Hello,
I am having this same issue and have tried all the recommended steps can you try sending the token reset to mine as well?
Riclicious,
amyglen
Hi James,
Can I have a token reset sent to my base station too?
Thanks!
