Hub Sounds
Dear Team,
I wanted to express my satisfaction with my Arlo products thus far. The home security system, in particular, has been exceptional in notifying me when a door is opened. However, I believe it would greatly enhance the system's functionality if it could specify which door is being opened. Having this feature would provide valuable information about individuals entering or leaving my residence.
Thank you.
HI @MysticSky
Thank you for sharing your positive feedback. Regarding your feedback with the sensors, you can name them within the app under Devices > Select the sensor > Settings wheel in the top right > Select the Sensor at the top > Select Edit and adjust the name.
After renaming, when you receive a notification it will be labeled with the name you chose for easier differentiation.
I hope that helps.
AppleTV
21 -
Samsung SmartThings
59 -
Security System
