- English
- Arlo Forum Discussions
- Partner Integrations
- Re: HomeKit setup button missing for Ultra Base St...
Hi, I'm trying to setup HomeKit on my Arlo Ultra 2-camera system, and I'm struggling.
I'm following this guide: https://kb.arlo.com/000062279/How-do-I-connect-my-Arlo-camera-to-Apple-HomeKit
Since I don't see a HomeKit setup code on the base station or the setup guide, I'm using the "To setup an Arlo camera without a setup code:" section.
1.) I see that I'm running the proper firmware on my VMB5000: 1.14.0.9_137_8e45094
2.) I'm connected to my router's local WiFi. I can ping the base station from my iPhone.
3.) I've already setup the Home app and I have a few lights configured that work fine.
4.) When I open the Arlo app and go to the base station settings, there's no "HomeKit" button.
I found this video on YouTube about setting up previous gen Arlo cameras on HomeKit, and it shows the mentioned "HomeKit" button under the base station settings. I don't see this same button on my end. https://www.youtube.com/watch?v=aoM-YNSYBCo
Am I missing something?- Is there an update to the Arlo app that hasn't made it through approval yet? Is there a HomeKit code somewhere in the packaging that I misplaced?
Had this issue with no HomeKit button, this worked to get the HomeKit button showing and everything working in HomeKit.
Short version - added the hub and camera to the app, no HomeKit button, removed the hub, while doing that got a weird message about needing access to my home (that I never saw during set up) and clicked ok, and when I re-added the hub, the HomeKit button was now there and was able to set everything up in Homekit / see the cameras with live video et. al. in the Apple Home app and everything.
Longer version:
I had the same issue mentioned above where I set up everything: added base station and camera in Arlo App on my iPhone, updated firmware on my base station (to 1.14.0.9_137_8e45094) and updated firmware on my cameras BUT NEVER SAW THE HOMEKIT BUTTON in SETTINGS. After doing other stuff for a couple hours, came back and still no HomeKit button so decided to try some haphazard troubleshooting. First thing I did was, in the Arlo app on my iPhone (with 'Devices' tab selected in the bottom nav bar), clicked on the "SmartHub / Base Station / Bridge" button, which took me to the hub's 'Device Settings' page, scrolled to the bottom where there was a Restart button and Remove Device button, clicked Remove Device. When I did that, got an unexpected message saying something like "Your hub needs access to your Home..." or something like that (unfortunately didn't take a screen shot and just clicked 'ok' - don't think there was even another option besides ok.) But, it then removed the hub and the camera I had added previously. Then, I re-added the hub, and when I did, there was a 'HomeKit' button on the hub settings page and was able to set everything up in HomeKit including seeing the cameras with live video et. al. in the Apple Home app.
I'm having the exact same issue. I've even talked to Arlo support and we went through all the steps with no help. Last thing he wanted was to upload screen shots of the page but that disconnected us from chat and I haven't got back to them.
The Homekit button is just not there and without a Homekit code nothing I can do.
I'm on iPhone 11 Pro iOS 13.1.3
Hopefully they come up with a fix soon.
I have the same issue. Everything updated to latest version. No HomeKit button on my iPad Pro and on my iPhone 11 Pro...
Longer version:
Your solution worked for me. Thank you.
Thanks for going through the trouble of figuring this out for us. I really hope Arlo releases an update that resolves this bug. That was not a fun fix!
AppleTV
21 -
Samsung SmartThings
59 -
Security System
