I just recently bought the SmartHub VMB 4540 and would like to add it to my HomeKit but it would like the setup code and I cannot find it anywhere. I have tried to set up with and without the code. Can you please help?
HomeKit pairing is usually made within the mobile arlo app. Base/settings/HomeKit.
If it fails to discover then you will likely need to request a base station token reset by a arlo moderator or from the customer support team.
Please find the following How-To article that will guide you through this process.
https://kb.arlo.com/000062279/How-do-I-connect-my-Arlo-device-to-Apple-HomeKit
Thank you
AppleTV
21 -
Samsung SmartThings
59 -
Security System
