James, could you please send a token update to my base station as well..
thanks, much appreciated
My base station still does not work with HomeKit. I just did a factory reset this afternoon and brought all of my cameras back online. Can I please get a reset token ASAP?
The fix for this issue has started rolling out. Please update your Arlo mobile app manually from the iOS store to version 3.5.1 and if you're still experiencing the issue, reach out to me in a private message with your e-mail address and I can send your system a HomeKit token reset.
Thank you
Looks like I will need a reset token and new HomeKit certificate number. Can you assist?
the update works helps that but camera wont play need token reset
My base station failed twice adding to HomeKit. Rebooted, now stuck 'Requesting HomeKit info...'
Do I need a token reset?
I’ve updated the app and rebooted all my bases. Still not working 😞
Henrychung828
I have reset your HomeKit token, please reboot your base and try again.
I needed to reset my Arlo Baby a couple of days ago and even with the lastest version of the app installed on my iPhone (3.5.1) it remains pending waiting to contact the device. What can I do ?
Hello @ShayneS ,
I tried to restart my Arlo Baby once I've got your message, even doing a rest of my device, add it again into the Arlo App, and then trying to add it using the App or directly using Home app but none of them worked. It remains on an infinity loop saying "connection to the device..." even if the device is working well using the Arlo App... Very disappointing, don't know what to do more...
AppleTV
21 -
Samsung SmartThings
59 -
Security System
