spatel9114
I’ve set up my VMB4000 Base station with 1 Arlo Pro camera and 3 Arlo Essential cameras, and when I try and configure HomeKit on the base station, it gets stuck on the discovering step and won’t actually connect. Can I get some help?
783 REPLIES 783
AllanSilkeborg
Hi
Can I also get a token reset?
BR Allan
MarcGijs
Hi James,
Same problem.
Can you sent me a token as well?
neilaaron
I have am having the issues while adding the base station to homekit. Can I get a token reset as well.
ShayneS
Hi @green12 @AllanSilkeborg @MarcGijs @neilaaron
I have reset your tokens, please reboot your base station/Smart Hub and try again.
AllanSilkeborg
Thanks for the reset token but unfortunately it didn’t work. It is still searching like “forever”.
green12
thanks after reboot, i am able to setup homekit
ShayneS
Hi @AllanSilkeborg
I reset your token again. Can you reboot one more time and try again? If the issue persists, please contact customer support to further investigate the issue here: Arlo Tech Support
madar1a
Hi @ShayneS , Could you resend my token please? I just received Ultra 2 and get the same error when trying to set up HomeKit.
ShayneS
@madar1a
No problem, I reset it. Please reboot & try again.
madar1a
It works now, thank you!
wpgtek
Can get a reset token as well? Just received a VMB5000 and would like to add it to HomeKit.
BrianMyers
Nheuberger
Hello, I’m in the same boat. Can I request a token reset?
ShayneS
Hi @wpgtek @BrianMyers @Nheuberger
AllanSilkeborg
Could you please reset my token again? Thanks
wpgtek
Thanks I was able to add the Arlo VMB5000 to HomeKit.
ShayneS
Hi @AllanSilkeborg
wpgtek
So I was able to add the HUB to HomeKit but it is not showing the connected devices (2 ADV001 doorbells).  I have re-added the HUB to HomeKit multiple times - but no success.
cvapr
Hi Shane, could I please get my token reset..  thank you!
ShayneS
@cvapr
Done, Please reboot and try again.
cvapr
thank you. now it worked.
duggie
Hi, i had to take mine off homekit and wont add back, i think i just need a token reset please as this fixed it the last time
Thanks in advance
Romise
ReggiefromPA
@JamesC  i am having the same issue can you send the fix to me as well.
ShayneS
Hi @ReggiefromPA
I have reset your token, please reboot your base station/Smart Hub and try again.
