Laurianlee,
Are you able to name the devices something specific and then command alexa to "arm" the specific named devices? Does this result in different behavior?
Hi James: Thanks for your reply, much appreciated. As to your advice, yes, I have renamed the devices to completely different identities (Disney Characters!!) but unfortunately as soon as I enable the Arlo app and then try to arm the Yale alarm I get told by Alexa that there are two devices with the name 'Alarm'. I am normally very good at sorting this, but on this occasion I am stumped. I cannot work out what it is in the Arlo app that is causing the 'alarm' name conflict when the Arlo app is enabled. Very curious. Thanks again for your response.
AppleTV
21 -
Samsung SmartThings
59 -
Security System
