Hi every one Need help understanding the process!
i have a samsung srf9300bfh smart fridge.
I have Arlo Pro 4 cameras
how do i access them from the fridge ( like Ring)
there is no (smartthings app or Arlo on the Fridge)
Am I missing something?
Samsung SmartThings
LesKilby,
If the Smart fridge can use Google Assistant you may be able to utilize the Google integration with Arlo to view cameras. Take a look here: https://kb.arlo.com/000055108/How-do-I-connect-my-Arlo-cameras-to-Google-Home
ll sorted thankyou BTW
the fix is this
Move your cameras into Smarthings by samsung
I now cxan view my cameras on my fridge
AppleTV
21 -
Samsung SmartThings
59 -
Security System
