camara will not update firmware and won't record unless updated. battery operated camara
hardware - H7 Firmware 1.2.16720 Camera was working fine until request for firmware update. i have another camera just like it that updated just fine, but this one won't update and won't work unless updated, so it is useless now. i have tried everything. the batteries are new and full. i even removed the device from my account and reinstalled it. nothing will work. am i going to have to get rid of my camera just because i can't update?!
I had the same thing happen to me. One of my cameras work and the other one does not even tun on anymore. Battery are good.
TM27,
It could be a signal strength issue causing the firmware upgrade to fail. Try moving the camera (temporarily) close to the base station and see if you experience the same behavior.
Janetec
Just to clarify, this is an Arlo Wire Free? Have you tried plugging the camera in and updating?
Janetec,
If you need any further assistance the community & I will be glad to help
