What is the password
The base station wifi network is closed (only used by the Arlo cameras). So you don't (and can't) connect to their wifi from your phone or PC.
@Arrowj35 wrote:
I think mine was hacked. I want to get into it and find out which devices are logged into it or connected to it
You can't (the password isn't published).
Why do you think the base was hacked? What symptoms are you seeing?
Settings n modes r getting changed. Cameras are being shut off or disconnected. And Ive even went as far as changing my own login information twice.
Have you contacted support? https://www.arlo.com/en-us/support/contact.aspx One thing you could try is to reset the base (using the pinhole) and then re-add the cameras.
Have you considered turning on 2-factor authentication?
There are other possibilities on the hacking front - a hacked PC or phone could also be the vector (a keylogger on either device could track your password changes).
