Because the App is broken and it must be a low priority issue to resolve since they apparently are too busy adding more aditional features that will probably break more things that will also become low priority issues to fix ... just my observations
If you are using Android, the notification sound selection from the Arlo app seems inoperative. However after app update before the last tweak, on my S8+ the ability to change the sound through the phone has appeared (where it was not available before). Settings>Apps>Arlo>Notifications>Notifications>Sounds. This allowed me to change the notification sound.
That work around/method dosen't seem to be an option with pixel 2 XL running Android 9
Would be nice to see the option in the App just work instead of trying to figure out alternative methods
However, I am very leery of rolling back Arlo using a version downloaded from a third party like APKMirror. In this day and age of malicious software, third parties are easily hacked and their contents infested.
So the real question here is simple. If it can be done, why can't Arlo do it? Come on Arlo, you caused this problem, please make a rollback available for those with problems like us!
On Android......... go back to an earlier version of the app where notifications sounds can be changed in the app. I still have an older version and can change notification sounds at will. (I never went for the "upgrade", knew better with Arlo devs track record. My older version of the app just works, no need to "upgrade")
I have the Arlo Pro, Three Camera System purchased from Costco. I am using an Android, Samsung S8 phone.
Since the Arlo update that came out around 11/20/18, the Arlo App is now not allowing me to select a different ringtone for my Arlo notifications. If I go into Arlo settings (3 dots in upper right corner of Arlo App), select settings, select notifications, select Notification Tone, I can select whatever ringtone I want for the Arlo notifications, however it doesn't actually change the notification sound. My phone still gives me the Arlo notifications with the same tone as all my other texts, alerts, etc.
I would like to have a different tone for my Arlo notifications. This worked just fine prior to the 11/20/18 Arlo app update. Any ideas?
I also have the Arlo Pro and am experiencing the same issue. Hoping someone knows how to correct this issue.
I think I just figured it out! Go to your Settings App on your phone (not the Arlo App). Click on Notifications. Scroll down and touch the Arlo app. Touch Notifications on this screen. Go to where it says Sound. Change it to what you want. Make sure it matches what you have selected within the Arlo app itself. Once these two locations matched, it worked for me. Let me know if you have any questions.
Not being able to chnage the notifications sound directly in the app is a new bug introduced with last app updates. You can try the work around posted here or go back to an older android app where the notifications can be changed within the Arlo app again. I'm still on an older version of the app and can change sounds at will from within the app.
A link to old version or just Google arlo apk that's not a misspell it's apk
In any event, I gave up and bought a sensor doorbell to meet my immediate needs. Dad has also continued to deteriorate so we acquired a hospital bed with side rails. He is too weak to crawl over them. My whole concern has gone away due to other events - no thanks to Arlo whatsoever.
That said, I do continue to monitor this thread - especially since I started it in the first place. And I will also continue to provide updates - if and when Arlo ever gets around to fixing the issue.
Latest release 12/6/18 did not fix notifications
same here on my S9+ Android.
That and often the alerts don't go off unless I at least hit the button to light up the phone. When phone screen is off, no alerts.
The Arlo development team is currently investigating this issue. We will provide an update as soon as we have more information to share with the community. The Arlo development team is currently investigating this issue. We will provide an update as soon as we have more information to share with the community.
just adding to thread that I have same issue, I get a notification, it's just not the sound I picked, it's the default sound of the phone
Hello,
I've had my arlo cameras for a while now. I like the cameras and really like the visualupdatese however with the most recent update I can not change the sound setting. By that I mean that no matter what sound I choose, even silent, i still get a default sound notification. It's kind of annoying when I'm home working in the yard and my phone is chiming all day long. Any suggestions before I switch over to nest cam?
It's a bug taht I'm sure will be fixed. However, why not turn the camera(s) off or use the Disarmed mode to eliminate all of the extra recordings and notifications?
If on android......... install an older version of the arlo app and you'll be able to change your sounds like your supposed to. Otherwise have to wait until the bug is fixed. iPhone users must wait as well.
