Im having problems with my cameras recording. I would like them to record from 10pm to 8am. i would like them to record nonstop at this time but its not working. I press the record button on both of my live feeds the first night it only taped for 3 hrs then turned off. Now last night I had it armed for motion detection wich I dont really want and the system shut down at midnight. I tried using the schedule and that is just a pain it dont want to save for me at the times I want it. Can someone help me figure out what is wrong I payed alot od money for these security cameras hoping they would be easy.
These cameras are NOT designed to record continuously .... they are "detect motion then record" type of system.
To record all the time the batteries will go dead in a short time instead of months.
So ARM the camera and let it sense motion and record as it should
If using Schedule, you cannot set the time THRU midnight...you set it up say 8pm to 1159pm and the next day at 12 midnight to continue as needed say 6am
